ヘルプ
Canon Selphy CP720 Cooling Fan Replacement
This guide demonstrates the replacement of the internal fan in the Selhpy CP720.
  • 作成者: Peter Ely
  • 所要時間: 10分
  • 難易度: 普通
This guide shows how to replace the cooling fan on the Selphy CP720. This is done to fix overheating problems caused by a faulty fan.
手順 1 Cooling Fan  ¶
Remove the four 8mm Phillips #1 screws from the bottom of the printer. Remove the four 8mm Phillips #1 screws from the bottom of the printer.
手順 1 Cooling Fan  ¶
  • Remove the four 8mm Phillips #1 screws from the bottom of the printer.
手順 2  ¶
Gently lift the top half of the printer off its base
手順 2  ¶
  • Gently lift the top half of the printer off its base
  • A data ribbon attaches the two halves, so don't pull hard and keep the two halves close together.
手順 3  ¶
Remove the side panel by lifting it out. Remove the side panel by lifting it out. Remove the side panel by lifting it out.
手順 3  ¶
  • Remove the side panel by lifting it out.
手順 4  ¶
Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port. Do not tug on the wires.  Slowly increasing force as you pull is the best way to detach the wires.
手順 4  ¶
  • Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
  • Do not tug on the wires. Slowly increasing force as you pull is the best way to detach the wires.
手順 5  ¶
Unscrew the two 8mm Phillips #1 screws from the fan.
手順 5  ¶
  • Unscrew the two 8mm Phillips #1 screws from the fan.
  • Remove the fan from the panel.
