メインコンテンツにスキップ
ヘルプ
Hover-1 Folding E-Scooter Brake Pad Replacement
This guide will show you how to replace the brake pad on a Hover-1 Folding E-Scooter.
  • 作成者: Meagan Chan
  • 所要時間: 25 - 50 分
  • 難易度: 簡単
Are you riding with risk because your brake no longer slows down your scooter? Learn how to replace your brake pad to make your scooter safe to ride again.
手順 1 Brake Pad  ¶
Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise. Twist the screwdriver clockwise to reassemble.
手順 1 Brake Pad  ¶
  • Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
  • Twist the screwdriver clockwise to reassemble.
  • There are also two nuts that secure the screws.
手順 2  ¶
Wobble to remove the brake step. Wobble to remove the brake step. Wobble to remove the brake step.
手順 2  ¶
  • Wobble to remove the brake step.
手順 3  ¶
Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise. Twist the screwdriver clockwise to secure the screws.
手順 3  ¶
  • Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise.
  • Twist the screwdriver clockwise to secure the screws.
手順 4  ¶
Remove the brake pad. Remove the brake pad. Remove the brake pad.
手順 4  ¶
  • Remove the brake pad.
