ヘルプ
Samsung Galaxy Tab E 8.0 Motherboard Replacement
Replacing the motherboard on the interior of the Samsung Galaxy Tab E 8.0. Model of device is SM-T377V.
  • 作成者: Chrissy B
  • 所要時間: 15 - 20 分
  • 難易度: 普通
The motherboard of the Samsung Galaxy Tab E 8.0 may malfunction after overuse of the device. This guide will show how to replace the tablet's motherboard, which is attached to the front panel.
セクション
手順 1 Motherboard  ¶
Use the tweezers to flip the switch on the bottom of the strap that goes over the battery. Release the strap from the switch by lifting the strap with your hand.
手順 1 Motherboard  ¶
  • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
  • Release the strap from the switch by lifting the strap with your hand.
手順 2  ¶
Use the tweezers to flip the switch that connects the top of the strap to the motherboard. Lift the top end of the strap with your hand and remove the strap completely from the device.
手順 2  ¶
  • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
  • Lift the top end of the strap with your hand and remove the strap completely from the device.
手順 3  ¶
Use the tweezers to flip the switch of the connector. Lift the connector from the motherboard.
手順 3  ¶
  • Use the tweezers to flip the switch of the connector.
  • Lift the connector from the motherboard.
  • This connector does not come completely off, but disconnects from the motherboard.
手順 4  ¶
Use the tweezers to flip the switch of the blue connector on the motherboard. Lift the connector from the motherboard.
手順 4  ¶
  • Use the tweezers to flip the switch of the blue connector on the motherboard.
  • This switch can detach from the device, but just needs to disconnect from the motherboard.
  • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
手順 5  ¶
Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard. Lift the connector from the motherboard.
手順 5  ¶
  • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
手順 6  ¶
Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard. Lift the motherboard with your hand to detach the motherboard from the device.
手順 6  ¶
  • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
  • Lift the motherboard with your hand to detach the motherboard from the device.
