ヘルプ
Disassembling HP Mini 210 Back Case
手順の記述もれ
手順の記述もれ
申し訳ございませんがこのガイドは、いくつかの重要なステップが不足しています。
Removing the back case on this computer so you can get inside.
  • 作成者: Heather Freed
  • 所要時間: 2分
  • 難易度: 簡単
Removing the back case is easy and snaps right off, giving you access to all the parts inside.
セクション
ツール
手順 1 Disassembling HP Mini 210 Back Case  ¶
Turn the netbook to view its edge.
  • Turn the netbook to view its edge.
  • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
手順 2  ¶
If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
手順 2  ¶
  • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
手順 3  ¶
Pull the back case off from the front edge.
手順 3  ¶
  • Pull the back case off from the front edge.
