メインコンテンツにスキップ
ヘルプ
HP Chromebox J5N50UT Bottom Shield Replacement
Replace the bottom shield of your HP Chromebox (model number J5N5OUT).
  • 作成者: Ashley Marvin
  • 所要時間: 5 - 10 分
  • 難易度: 普通
If the Bottom Shield of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom shield. For this guide, you will need the Philips #1 screwdriver .
セクション
ツール
手順 1 Bottom Shield  ¶
Lift the two pieces of mylar tape from the bracket.
  • Lift the two pieces of mylar tape from the bracket.
手順 2  ¶
Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
手順 2  ¶
  • Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
手順 3  ¶
Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
手順 3  ¶
  • Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
