メインコンテンツにスキップ
ヘルプ
Apple Watch Series 2 Battery Disconnection - prereq
必要条件のみ
必要条件のみ
このガイドは他のガイドにとって唯一の必要条件であることに注意してください。
手順 1 Battery Disconnection  ¶
Remove the Tri-point #000 screw securing the metal battery connector cover. Use a pair of tweezers to remove the cover.
  • Remove the Tri-point #000 screw securing the metal battery connector cover.
  • Use a pair of tweezers to remove the cover.
手順 2  ¶
Disconnect the battery by prying its connector straight up with the edge of a spudger. Bend the connector up slightly to make sure it does not make contact by accident.
手順 2  ¶
  • Disconnect the battery by prying its connector straight up with the edge of a spudger.
  • Bend the connector up slightly to make sure it does not make contact by accident.
