メインコンテンツにスキップ
ヘルプ
Trek 820 Spokes Replacement
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
文法の修正
文法の修正
あなたの中にある日本語能力を呼び起こし、このガイドの文法に磨きをかけましょう。
アクションショット
アクションショット
アクションヒーローになりましょう!このガイドはある特定の動作をどのように行なうのか、より詳細な画像が必要です。
進行中
進行中
このガイドは現在作成中です。最新の変更を見るために定期的に再読み込みしてください。
より良い紹介部分
より良い紹介部分
この紹介部分を完成し編集することでこのガイドを改良する
This guide will show you how to remove the spokes from the rim of your tire.
手順 1 Spokes  ¶
Make sure you have removed the tires as shown in the prerequisite guides. Slowly peel back the layer of rubber that  covers the 32 screws on the tire .
手順 1 Spokes  ¶
  • Make sure you have removed the tires as shown in the prerequisite guides.
  • Slowly peel back the layer of rubber that covers the 32 screws on the tire .
手順 2  ¶
You will need a flathead screwdriver You will need to alternate between steps #2 and #3 because the spokes have to be removed one  at a time. Remove the screw using the flathead.
手順 2  ¶
  • You will need a flathead screwdriver
  • You will need to alternate between steps #2 and #3 because the spokes have to be removed one at a time.
  • Remove the screw using the flathead.
  • All screws will be the same size.
  • Only remove the screws of the spokes you are replacing.
手順 3  ¶
Once a screw is removed gently remove the spoke from the rim of the tire  if it did not fall out. Maneuver the spoke so that it is perpendicular then slide the spoke out. Maneuver the spoke so that it is perpendicular then slide the spoke out.
手順 3  ¶
  • Once a screw is removed gently remove the spoke from the rim of the tire if it did not fall out.
  • Maneuver the spoke so that it is perpendicular then slide the spoke out.
手順 4  ¶
Insert the new spoke into the missing hole.
手順 4  ¶
  • Insert the new spoke into the missing hole.
  • If you are replacing multiple spoke , you will need to alternate between steps #4, and #5 . The spokes must be replaced one at a time.
手順 5  ¶
Use the flat head screw driver to insert a  screw  to stop the spoke from falling out.
手順 5  ¶
  • Use the flat head screw driver to insert a screw to stop the spoke from falling out.
