メインコンテンツにスキップ
ヘルプ
Mac mini Model A1176 IR Board & Cable Replacement
Replace your IR board to regain control of your mini via an Apple remote.
セクション
手順 1 IR Board & Cable  ¶
Remove the single Phillips screw securing the IR board to the internal frame.
  • Remove the single Phillips screw securing the IR board to the internal frame.
手順 2  ¶
De-route the IR board and cable through the channel near the hard drive in the internal frame.
手順 2  ¶
  • De-route the IR board and cable through the channel near the hard drive in the internal frame.
手順 3  ¶
Flip the internal frame over.
手順 3  ¶
  • Flip the internal frame over.
  • De-route the IR board and cable through the channel within the internal frame.
手順 4  ¶
De-route the IR board and cable through the small plastic clip in the internal frame.
手順 4  ¶
  • De-route the IR board and cable through the small plastic clip in the internal frame.
手順 5  ¶
Use your fingers to disconnect the IR cable connector from its socket on the interconnect board. Make sure to pull straight out, and to pull on the connector and not the cable.
手順 5  ¶
  • Use your fingers to disconnect the IR cable connector from its socket on the interconnect board. Make sure to pull straight out, and to pull on the connector and not the cable.
