ヘルプ
Outer Shell Disassembly
スライスとサイコロ
スライスとサイコロ
このガイドの手順は分割され必要条件ガイドのシリーズに含まれるべきです。
The removal of the covers and simple internal components allow for repair and maintenance of the printer.
  • 作成者: Renee Lamb
  • 所要時間: 30分
  • 難易度: 普通
The process of removing covers and simple internal components requires minimal technical experience.
手順 1 Outer Shell Disassembly  ¶
Unplug the device from any energy sources. Lift the top cover of the scanner.
  • Unplug the device from any energy sources.
  • Lift the top cover of the scanner.
  • Use a plastic opening tool to remove the plastic frame surrounding the glass.
手順 2  ¶
Carefully pull the frame away from the glass.
手順 2  ¶
  • Carefully pull the frame away from the glass.
  • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
手順 3  ¶
Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
手順 3  ¶
  • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
手順 4  ¶
Put your finger behind the panel with the power button. Then, pull the piece outwards.
手順 4  ¶
  • Put your finger behind the panel with the power button.
  • Then, pull the piece outwards.
手順 5  ¶
Unscrew the screw inside the power button panel space. Then, unscrew the screw that is across the printer slider.
手順 5  ¶
  • Unscrew the screw inside the power button panel space.
  • Then, unscrew the screw that is across the printer slider.
手順 6  ¶
Pull the white circuit board outwards which is located under the small screen.
手順 6  ¶
  • Pull the white circuit board outwards which is located under the small screen.
  • Unplug the small ribbon cable from the circuit board.
  • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
手順 7  ¶
画像がありません
手順 7  ¶
  • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
手順 8  ¶
Pull the memory card reader's circuit board out. Detach the white wiring connector from the back of the circuit board.
手順 8  ¶
  • Pull the memory card reader's circuit board out.
  • Detach the white wiring connector from the back of the circuit board.
  • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
手順 9  ¶
Put your finger behind the small screen. Then, pull it up.
手順 9  ¶
  • Put your finger behind the small screen.
  • Then, pull it up.
  • Do not hesitate to use force to remove the TouchSmart panel.
  • Disconnect the ribbon cable from the small screen.
手順 10  ¶
Pull the printer hood upward.
手順 10  ¶
  • Pull the printer hood upward.
