メインコンテンツにスキップ
ヘルプ
Disassembling & Replacing Keyboard on Toshiba Laptop C655 Series
アクションショット
アクションショット
アクションヒーローになりましょう!このガイドはある特定の動作をどのように行なうのか、より詳細な画像が必要です。
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
How to accomplish the simple task of disassembling and replacing the keyboard on a Toshiba C655 series.
  • 作成者: Rany
  • 所要時間: 10分
  • 難易度: とても簡単
手順 1 Keyboard  ¶
Make sure the laptop is powered off before starting. Remove the battery.
手順 1 Keyboard  ¶
  • Make sure the laptop is powered off before starting. Remove the battery.
  • Use a plastic opening tool to pry out the narrow plastic lid.
  • You may use a flat-head screwdriver for this task, but will most likely scratch the keyboard and the plastic lid itself.
  • Exercise caution when re-assembling: carefully and gently snap the lid back on. The plastic lid may easily break since it is made of a thin and soft plastic material.
  • Before replacing the lid, you may want to power on the laptop and test that the keyboard is working properly.
手順 2  ¶
Remove the following screws securing the top of the keyboard:
手順 2  ¶
  • Remove the following screws securing the top of the keyboard:
  • Four 3mm Phillips screws.
手順 3  ¶
In this next step, the keyboard is still attached to the logic board via a flat cable. Be careful not to tear the cable or damage the connector by removing the keyboard too quickly or too abruptly or pulling it too far away from the laptop.
手順 3  ¶
  • In this next step, the keyboard is still attached to the logic board via a flat cable. Be careful not to tear the cable or damage the connector by removing the keyboard too quickly or too abruptly or pulling it too far away from the laptop.
  • Lift the keyboard away from the laptop, starting from the top end which is nearest to the screen.
手順 4  ¶
Use the tip or the flat end of a nylon spudger to unlock the connector securing the flat cable of the keyboard to the logic board. Pull the flat cable out not up.
手順 4  ¶
  • Use the tip or the flat end of a nylon spudger to unlock the connector securing the flat cable of the keyboard to the logic board.
  • Pull the flat cable out not up.
  • When re-assembling, insert and hold the flat cable in place with one hand; use the other hand to lock the connecter using the tip or flat end of a nylon spudger. If you release the flat cable before locking the connector, it will most probably slip out.
