メインコンテンツにスキップ
ヘルプ
Mac mini Model A1283 Optical Drive Replacement
必要条件のみ
必要条件のみ
このガイドは他のガイドにとって唯一の必要条件であることに注意してください。
Remove the optical drive from your mini.
セクション
手順 1 Optical Drive  ¶
Use the tip of a spudger to remove the black electrical tape spanning the interconnect board and optical drive. Use the tip of a spudger to remove the black electrical tape spanning the interconnect board and optical drive.
  • Use the tip of a spudger to remove the black electrical tape spanning the interconnect board and optical drive.
手順 2  ¶
Use the flat end of a spudger to disconnect the audio ribbon cable from the interconnect board.
手順 2  ¶
  • Use the flat end of a spudger to disconnect the audio ribbon cable from the interconnect board.
手順 3  ¶
If necessary, remove the yellow kapton tape covering the internal frame and the optical drive.
手順 3  ¶
  • If necessary, remove the yellow kapton tape covering the internal frame and the optical drive.
手順 4  ¶
Remove the two Phillips screws securing the optical drive to the internal frame.
手順 4  ¶
  • Remove the two Phillips screws securing the optical drive to the internal frame.
手順 5  ¶
Turn the mini 180 degrees and remove the two Phillips screws securing the optical drive to the internal frame on the other side.
手順 5  ¶
  • Turn the mini 180 degrees and remove the two Phillips screws securing the optical drive to the internal frame on the other side.
手順 6  ¶
Remove the two Phillips screws securing the interconnect board to the optical drive.
手順 6  ¶
  • Remove the two Phillips screws securing the interconnect board to the optical drive.
手順 7  ¶
Insert the flat end of a spudger into the crevice between the optical drive and the interconnect board.
手順 7  ¶
  • Insert the flat end of a spudger into the crevice between the optical drive and the interconnect board.
  • Carefully increase the crevice to disconnect the optical drive from the interconnect board.
手順 8  ¶
Gently lift the optical drive out of the internal frame.
手順 8  ¶
  • Gently lift the optical drive out of the internal frame.
