メインコンテンツにスキップ
ヘルプ
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Display Replacement
Change out the entire display assembly, including the inverter, AirPort antenna, hinges and metal casing.
セクション
ファイル
手順 1 Display  ¶
Pull the display data cable away from its socket to disconnect it from the logic board.
手順 1 Display  ¶
  • Pull the display data cable away from its socket to disconnect it from the logic board.
  • Be sure to pull only parallel to the face of the logic board, as pulling up on the socket will break it off the logic board.
手順 2  ¶
If necessary, use the tip of a spudger to remove the small piece of foam tape from the side of the left speaker.
手順 2  ¶
  • If necessary, use the tip of a spudger to remove the small piece of foam tape from the side of the left speaker.
手順 3  ¶
Disconnect the inverter cable from the logic board.
手順 3  ¶
  • Disconnect the inverter cable from the logic board.
  • When pulling this connector away from its socket, it is helpful to use your fingernails to pull on the ears at each side of the connector.
手順 4  ¶
De-route both AirPort/Bluetooth antennas and the inverter cable from underneath the DC-in board ribbon cable.
手順 4  ¶
  • De-route both AirPort/Bluetooth antennas and the inverter cable from underneath the DC-in board ribbon cable.
  • It is not necessary to remove the DC-in board cable.
手順 5  ¶
Before proceeding, be sure your display is perpendicular to the lower case.
手順 5  ¶
  • Before proceeding, be sure your display is perpendicular to the lower case.
  • Remove four T6 Torx screws from the left display hinge. 2- 8 mm and 1 -10 mm and one 6 mm left to right.
  • We intentionally have you leave one screw in the left display hinge to aid in disassembly.
  • The screw holding the plastic display cable bracket to the lower case is shorter than the rest.
手順 6  ¶
Remove four T6 Torx screws from the right display hinge.  2- 8 mm and 1 -10 mm and one 6 mm right to left.
手順 6  ¶
  • Remove four T6 Torx screws from the right display hinge. 2- 8 mm and 1 -10 mm and one 6 mm right to left.
  • We intentionally have you leave one screw in the right display hinge to aid in disassembly.
手順 7  ¶
While supporting the display with one hand, remove the one remaining T6 10 mm Torx screw from each display bracket (two screws total).
手順 7  ¶
  • While supporting the display with one hand, remove the one remaining T6 10 mm Torx screw from each display bracket (two screws total).
手順 8  ¶
Lift the display straight up from the lower case, minding any cables that may get caught.
手順 8  ¶
  • Lift the display straight up from the lower case, minding any cables that may get caught.
手順 9  ¶
Here are a few tips for reassembling the display. These apply to both the left and right display brackets: A small bracket (shown in red) near either side of the clutch cover is free to rotate about the display hinge and must be inserted behind the heat sink framework for the display to seat properly. Before completely lowering the display onto the lower case, use a spudger to rotate the bracket toward the rear edge of your PowerBook, and insert the bracket between the heat sink framework and the adjacent spring. The second picture shows the bracket correctly installed.
手順 9  ¶
  • Here are a few tips for reassembling the display. These apply to both the left and right display brackets:
  • A small bracket (shown in red) near either side of the clutch cover is free to rotate about the display hinge and must be inserted behind the heat sink framework for the display to seat properly.
  • Before completely lowering the display onto the lower case, use a spudger to rotate the bracket toward the rear edge of your PowerBook, and insert the bracket between the heat sink framework and the adjacent spring. The second picture shows the bracket correctly installed.
  • When removing the display screws, keep track of the thin metal bracket (shown in green) under the screws on the inner display bracket.
  • The outer display bracket (shown in orange) simply slides onto the spiral display spring. Be sure to press it on before installing your display into the lower case.
