メインコンテンツにスキップ
ヘルプ
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Modem Replacement
Replace your modem to regain dial-up internet access.
セクション
ファイル
ツール
手順 1 Modem  ¶
If necessary, peel back the strip of aluminum tape covering the modem cable.
手順 1 Modem  ¶
  • If necessary, peel back the strip of aluminum tape covering the modem cable.
手順 2  ¶
Use the flat end of a spudger to pry the modem cable connector up off the modem.
手順 2  ¶
  • Use the flat end of a spudger to pry the modem cable connector up off the modem.
手順 3  ¶
Disconnect the RJ-11 cable from the modem.
手順 3  ¶
  • Disconnect the RJ-11 cable from the modem.
手順 4  ¶
Use a 4 mm nut driver to remove the two nuts securing the modem to the PC card cage.
手順 4  ¶
  • Use a 4 mm nut driver to remove the two nuts securing the modem to the PC card cage.
手順 5  ¶
Lift the modem straight up off the studs on the PC card cage.
手順 5  ¶
  • Lift the modem straight up off the studs on the PC card cage.
