メインコンテンツにスキップ
ヘルプ
Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
Removal and replacement of the the motherboard for the Mitsubishi Diamondpoint LCD.
手順 1 Remove the 5 screws  ¶
Remove the two 24mm Phillips #2 screws.
  • Remove the two 24mm Phillips #2 screws.
  • Remove the three 8mm Phillips #2 screws.
手順 2 Remove the back panel  ¶
Lift the back and pry the back off. The panel is held in with clips on the side. It needs a lot of force the take it off. The panel is held in with clips on the side. It needs a lot of force the take it off.
  • Lift the back and pry the back off.
  • The panel is held in with clips on the side. It needs a lot of force the take it off.
手順 3 Remove the four screws  ¶
Remove the four 5mm nut screws. Remove the four 5mm nut screws.
  • Remove the four 5mm nut screws.
手順 4 Remove the 5 screws  ¶
Remove the seven Phillips #1 screws. Remove the seven Phillips #1 screws.
  • Remove the seven Phillips #1 screws.
手順 5 Remove the cables  ¶
Remove all the cables. Remove all the cables. Remove all the cables.
  • Remove all the cables.
手順 6 Remove the motherboard  ¶
Remove the four screws. Pull the motherboard up and off. Pull the motherboard up and off.
  • Remove the four screws.
  • Pull the motherboard up and off.
手順 7  ¶
Now you can replace it with a new one.
手順 7  ¶
  • Now you can replace it with a new one.
