はじめに
The second most significant repair for the monitor, the motherboard serves as the brain of its operation, and holds key components such as the charging port and other portions such as the CPU. Fortunately, this repair is also straightforward, as the motherboard is solely held in by screws, and a number of connectors that link it to the rest of the housing.
必要な工具と部品
Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
Lay the display face down on a table, to expose the back of the screen.
Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
