メインコンテンツにスキップ
eufy Security SpaceView Monitor Battery Replacement
必要な工具と部品
  1. eufy Security SpaceView Monitor Battery Replacement, Display Assembly: 手順 1、 2の画像 1 eufy Security SpaceView Monitor Battery Replacement, Display Assembly: 手順 1、 2の画像 2
    • Use an opening tool to press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Battery Replacement, Lift the display: 手順 2、 1の画像 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Battery Replacement, Screen: 手順 3、 1の画像 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Battery Replacement: 手順 4、 2の画像 1 eufy Security SpaceView Monitor Battery Replacement: 手順 4、 2の画像 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Battery Replacement: 手順 5、 1の画像 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
  6. eufy Security SpaceView Monitor Battery Replacement, Motherboard: 手順 6、 2の画像 1 eufy Security SpaceView Monitor Battery Replacement, Motherboard: 手順 6、 2の画像 2
    • Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
  7. eufy Security SpaceView Monitor Battery Replacement: 手順 7、 3の画像 1 eufy Security SpaceView Monitor Battery Replacement: 手順 7、 3の画像 2 eufy Security SpaceView Monitor Battery Replacement: 手順 7、 3の画像 3
    • Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
    • Pull the white ribbon connector from the motherboard, on the side closest to the battery.
    • Lift the motherboard and disconnect the antenna connector from its port.
    • The motherboard is free from the housing and can be replaced.
  8. eufy Security SpaceView Monitor Battery Replacement, Battery: 手順 8、 1の画像 1
    • Using a Jimmy, place the tool behind the battery where the glue is visible.
  9. eufy Security SpaceView Monitor Battery Replacement: 手順 9、 1の画像 1
    • Pry the battery from the monitor case.
終わりに
作成者
1人の作成者と共同作成されました。
Declan Andrews
メンバー登録日: 10/31/23
181 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023人のメンバー
UMASSD-GULBRANDSEN-F23S2G5
3 メンバー
6のガイドは作成済み
3件のガイドコメント
I can't find any info on suitable replacement batteries. There isn't a model number on the battery, just the following: FT804163P 2900mAh 11.02Wh BHZKF28L 3.8V. Where did you source your replacement battery from?
Trevor Graham - 返信
I used this one from ebay (104050, 2500mAh, the 1.25mm connector version): https://www.ebay.com/itm/115814771499 referenced by this reddit comment: https://www.reddit.com/r/techsupport/com...
I had to splice and swap the red/black wires as they were in the wrong order for the spaceview, but other than that, it fit in the monitor casing and worked as expected.
spacewarp - 返信
Do you know how to open up the camera to the Eufy Spaceview Pro? The monitor works but the camera's micro usb housing got pushed inside, so the usb power cable is loose and won't stay connected to the camera. Please help! Thank you!
Lucy - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 50
過去 30 日: 223
今までの合計 3,645
