メインコンテンツにスキップ
enTourage Pocket eDGe Motherboard Replacement
必要な工具と部品
  1. enTourage Pocket eDGe Motherboard Replacement, Battery: 手順 1、 3の画像 1 enTourage Pocket eDGe Motherboard Replacement, Battery: 手順 1、 3の画像 2 enTourage Pocket eDGe Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Motherboard Replacement: 手順 2、 1の画像 1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Motherboard Replacement: 手順 3、 3の画像 1 enTourage Pocket eDGe Motherboard Replacement: 手順 3、 3の画像 2 enTourage Pocket eDGe Motherboard Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Motherboard Replacement: 手順 4、 1の画像 1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Motherboard Replacement: 手順 5、 1の画像 1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
  6. enTourage Pocket eDGe Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 enTourage Pocket eDGe Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Locate the side of the device containing the motherboard.
    • Using your J0 Phillips head screwdriver, remove the three 5mm screws from the bottom of the motherboard.
    • Using your J0 Phillips head screwdriver, remove the four 3mm screws from the top of the motherboard.
  7. enTourage Pocket eDGe Motherboard Replacement: 手順 7、 1の画像 1
    • Using the plastic spudger, carefully pry the bottom of the motherboard up and away from the casing.
  8. enTourage Pocket eDGe Motherboard Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Position your device so the inside edge of the motherboard is closest to you.
    • Locate the three wires connecting the motherboard to the rest of the device.
    • Using your finger or a pair of tweezers, gently remove each of these from the motherboard.
  9. enTourage Pocket eDGe Motherboard Replacement: 手順 9、 1の画像 1
    • Lift the outer edge of the motherboard up. Carefully disconnect the 3 connections on bottom of the motherboard by pulling gently.
  10. enTourage Pocket eDGe Motherboard Replacement: 手順 10、 2の画像 1 enTourage Pocket eDGe Motherboard Replacement: 手順 10、 2の画像 2
    • The motherboard is now connected in only one place on the edge of the device. Being careful of this, flip the motherboard outside of the device, leaving it connected to the foam padding inside of the device.
    • Carefully pry the small rectangle apart from the thin strip of foam.
    • If the foam is still intact you may leave the foam in order to reattach the new motherboard.
ゴール
作成者
5人の作成者と共同で作成されました。
Adrian Do
メンバー登録日: 09/24/15
355 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 1-3, Sydow campbell Fall 2015 University of Alabama, Team 1-3, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G3
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 485
