メインコンテンツにスキップ
enTourage Pocket eDGe E-Reader Screen Replacement
必要な工具と部品
  1. enTourage Pocket eDGe E-Reader Screen Replacement, Battery: 手順 1、 3の画像 1 enTourage Pocket eDGe E-Reader Screen Replacement, Battery: 手順 1、 3の画像 2 enTourage Pocket eDGe E-Reader Screen Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 2、 1の画像 1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 3、 3の画像 1 enTourage Pocket eDGe E-Reader Screen Replacement: 手順 3、 3の画像 2 enTourage Pocket eDGe E-Reader Screen Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 4、 1の画像 1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 5、 1の画像 1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
  6. enTourage Pocket eDGe E-Reader Screen Replacement, E-Reader Screen: 手順 6、 2の画像 1 enTourage Pocket eDGe E-Reader Screen Replacement, E-Reader Screen: 手順 6、 2の画像 2
    • Locate the side of the device containing the motherboard.
    • Using your J0 Phillips head screwdriver, remove the three 5mm screws from the bottom of the motherboard.
    • Using your J0 Phillips head screwdriver, remove the four 3mm screws from the top of the motherboard.
  7. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 7、 1の画像 1
    • Using the plastic opening tool, carefully pry the bottom of the motherboard up and away from the casing.
  8. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Position your device so the inside edge of the motherboard is closest to you.
    • Locate the three wires connecting the motherboard to the rest of the device.
    • Using your finger or a pair of tweezers, gently remove each of these from the motherboard.
  9. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 9、 1の画像 1
    • Lift the outer edge of the motherboard up. Carefully disconnect the 3 connections on bottom of the motherboard by pulling gently.
  10. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 10、 1の画像 1
    • The motherboard is now connected in only one place on the edge of the device. Being careful of this, flip the motherboard outside of the device, leaving it connected to the foam padding inside of the device.
  11. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 11、 1の画像 1
    • Using your J0 Phillips head screwdriver, remove the one 5 mm screw holding the gray plastic e-reader screen backing into place.
  12. enTourage Pocket eDGe E-Reader Screen Replacement: 手順 12、 2の画像 1 enTourage Pocket eDGe E-Reader Screen Replacement: 手順 12、 2の画像 2
    • Carefully pry up the gray plastic e-reader screen using your finger and remove from the device.
ゴール
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Adrian Do
メンバー登録日: 09/24/15
355 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 1-3, Sydow campbell Fall 2015 University of Alabama, Team 1-3, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G3
4 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 678
