メインコンテンツにスキップ
eMac Shell Replacement
必要な工具と部品
  1. eMac Shell Replacement, Door Removal: 手順 1、 3の画像 1 eMac Shell Replacement, Door Removal: 手順 1、 3の画像 2 eMac Shell Replacement, Door Removal: 手順 1、 3の画像 3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. eMac Shell Replacement, Bottom Screw Removal: 手順 2、 1の画像 1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. eMac Shell Replacement, Top and Side Screws: 手順 3、 3の画像 1 eMac Shell Replacement, Top and Side Screws: 手順 3、 3の画像 2 eMac Shell Replacement, Top and Side Screws: 手順 3、 3の画像 3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. eMac Shell Replacement, Power Button Cable: 手順 4、 2の画像 1 eMac Shell Replacement, Power Button Cable: 手順 4、 2の画像 2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  5. eMac Shell Replacement, Shell Removal: 手順 5、 1の画像 1
    • Now the entire shell can be removed from the computer.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Chris Green
メンバー登録日: 10/11/09
37,065 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,488のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 34
今までの合計 2,035
