メインコンテンツにスキップ
dreamGEAR Quad Dock Pro Power Board Replacement
必要な工具と部品
  1. dreamGEAR Quad Dock Pro Power Board Replacement, Prerequisite Guide to Accessing Interior: 手順 1、 2の画像 1 dreamGEAR Quad Dock Pro Power Board Replacement, Prerequisite Guide to Accessing Interior: 手順 1、 2の画像 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Board Replacement: 手順 2、 2の画像 1 dreamGEAR Quad Dock Pro Power Board Replacement: 手順 2、 2の画像 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Board Replacement: 手順 3、 1の画像 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Board Replacement, Mother Board: 手順 4、 2の画像 1 dreamGEAR Quad Dock Pro Power Board Replacement, Mother Board: 手順 4、 2の画像 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Board Replacement: 手順 5、 1の画像 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Board Replacement: 手順 6、 2の画像 1 dreamGEAR Quad Dock Pro Power Board Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Board Replacement, Power Board: 手順 7、 2の画像 1 dreamGEAR Quad Dock Pro Power Board Replacement, Power Board: 手順 7、 2の画像 2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Board Replacement: 手順 8、 1の画像 1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Board Replacement: 手順 9、 1の画像 1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jacob
メンバー登録日: 03/11/15
757 ポイント
6のガイドは作成済み
チーム
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S4G4
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 250
