はじめに
This guide shows the steps in removing the part of Bob which holds the main brush and adjusts up and down for flooring transitions.
必要な工具と部品
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
The clutch end of the main brush, where the pin sits, is held inside Bob with one screw. It is found beside the power switch.
Use one hand to push the clutch up, then uninstall the screw and keep it aside for later.
Make sure to hold the clutch piece underneath bOb while installing the screw, so you can see the screw post protruding inside bObsweep.
When you’re finished, reattach the cover and install the main brush. Follow instructions in the Closing bObsweep's cover after repair
To close bObsweep after this repair, follow instructions in the Closing bObsweep's cover after repair
