はじめに
Is the LED Screen on the cover not lighting up? This guide will aid you in replacing the LED Screen. You will need a Phillips #1 screwdriver.
必要な工具と部品
Remove the two screws (9.9mm Phillips #1) next to the rotating front wheel.
Remove the two screws (9.9mm Phillips #1) below the wheels on either side of the dustbin compartment.
Remove the screw (9.9mm Phillips #1) to the side of the brush motor.
Remove the screw (9.9mm Phillips #1) inside the brush compartment.
Depress the tabs on the circuit plugs and lift them directly upward to remove:
The multicolored nine-wire circuit plug at the top edge of the board.
The red and black wire circuit plug directly next to it.
The seven white wire circuit plug on the bottom edge of the board.
The red, white, and black wire circuit plug on the bottom left corner of the board.
Remove and set aside the four screws (9.7 mm Phillips #1) on the underside of the cover that secure the screen.
