メインコンテンツにスキップ
bObsweep PetHair Plus WPP56002 Cover Replacement
必要な工具と部品
  1. bObsweep PetHair Plus WPP56002 Cover Replacement, Cover: 手順 1、 1の画像 1
    • Depress the tab on the side of the dustbin to disengage its latch. It is spring loaded and will partially pop out. Remove it from its housing.
  2. bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 2、 3の画像 1 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 2、 3の画像 2 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 2、 3の画像 3
    • Flip the bObsweep over and remove the main brush’s screw (13.7mm Flat) with a flathead screwdriver.
    • Lift and remove the main brush and its plastic bearing end cap.
  3. bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 3、 2の画像 1 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 3、 2の画像 2
    • Remove the two screws (9.9mm Phillips #1) next to the rotating front wheel.
    • Remove the two screws (9.9mm Phillips #1) below the wheels on either side of the dustbin compartment.
    • Remove the screw (9.9mm Phillips #1) to the side of the brush motor.
    • Remove the screw (9.9mm Phillips #1) inside the brush compartment.
  4. bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 4、 2の画像 1 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 4、 2の画像 2
    • Carefully hold the top and bottom halves together and flip the bObsweep upright.
    • Lift the cover to reveal the mainboard.
  5. bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 5、 3の画像 1 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 5、 3の画像 2 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 5、 3の画像 3
    • Slide the power inlet down.
    • Tuck it aside to protect it from damage.
  6. bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 6、 3の画像 1 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 6、 3の画像 2 bObsweep PetHair Plus WPP56002 Cover Replacement: 手順 6、 3の画像 3
    • Depress the tabs on the circuit plugs and lift them directly upward to remove:
    • The multicolored nine-wire circuit plug at the top edge of the board.
    • The red and black wire circuit plug directly next to it.
    • The seven white wire circuit plug on the bottom edge of the board.
    • The red, white, and black wire circuit plug on the bottom left corner of the board.
終わりに
Follows steps 6-9 for reassembly.
作成者
2人の作成者と共同で作成されました。
Saylor Price
メンバー登録日: 09/07/23
957 ポイント
7のガイドは作成済み
チーム
University of Memphis, Team 1-3, Sneed Fall 2023 University of Memphis, Team 1-3, Sneed Fall 2023人のメンバー
UM-SNEED-F23S1G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 56
