メインコンテンツにスキップ
bObi Robotic Vacuum Side Brush Motor Replacement
必要な工具と部品
  1. bObi Robotic Vacuum Side Brush Motor Replacement, Top Cover: 手順 1、 2の画像 1 bObi Robotic Vacuum Side Brush Motor Replacement, Top Cover: 手順 1、 2の画像 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Side Brush Motor Replacement: 手順 2、 3の画像 1 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 2、 3の画像 2 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 2、 3の画像 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Side Brush Motor Replacement: 手順 3、 3の画像 1 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 3、 3の画像 2 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 3、 3の画像 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Side Brush Motor Replacement: 手順 4、 3の画像 1 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 4、 3の画像 2 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 4、 3の画像 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Side Brush Motor Replacement, Side Brush Motor: 手順 5、 2の画像 1 bObi Robotic Vacuum Side Brush Motor Replacement, Side Brush Motor: 手順 5、 2の画像 2
    • The side brush motor is attached to the circuit board by one red and black twisted wire. Push down on the small white tab and pull to unplug it from the main board.
    • If there is glue holding it on bObi, use your screwdriver to break it off.
    • Remember to remove the screw and brush before trying to lift the motor out of bObi.
  6. bObi Robotic Vacuum Side Brush Motor Replacement: 手順 6、 3の画像 1 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 6、 3の画像 2 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 6、 3の画像 3
    • Uninstall the three screws holding the motor on bObi, then lift it straight up.
  7. bObi Robotic Vacuum Side Brush Motor Replacement: 手順 7、 3の画像 1 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 7、 3の画像 2 bObi Robotic Vacuum Side Brush Motor Replacement: 手順 7、 3の画像 3
    • Line up the motor with bObi's screw posts, and lower it in place.
    • Install the three screws.
    • Finish your repair by closing bObi. For detailed instructions, refer to: Closing bObi's Cover Post-Repair
終わりに
To close bObi when the repair is complete, follow this guide: Closing bObi's Cover Post-Repair
作成者
1人の作成者と共同作成されました。
Chelsea
メンバー登録日: 09/24/14
2,278 ポイント
31のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 360
