メインコンテンツにスキップ
bObi Pet Edge Sensors Replacement
必要な工具と部品
  1. bObi Pet Edge Sensors  Replacement, Turn bObi Pet Off: 手順 1、 3の画像 1 bObi Pet Edge Sensors  Replacement, Turn bObi Pet Off: 手順 1、 3の画像 2 bObi Pet Edge Sensors  Replacement, Turn bObi Pet Off: 手順 1、 3の画像 3
    • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
    • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
  2. bObi Pet Edge Sensors  Replacement, Remove the Front Wheel: 手順 2、 2の画像 1 bObi Pet Edge Sensors  Replacement, Remove the Front Wheel: 手順 2、 2の画像 2
    • Grip the front wheel and pull straight up, using the screwdriver for leverage.
    • The wheel will pop out and you will see two screws beneath it.
    • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
    • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
  3. bObi Pet Edge Sensors  Replacement, Remove the Dustbin's Holders: 手順 3、 3の画像 1 bObi Pet Edge Sensors  Replacement, Remove the Dustbin's Holders: 手順 3、 3の画像 2 bObi Pet Edge Sensors  Replacement, Remove the Dustbin's Holders: 手順 3、 3の画像 3
    • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
    • Grip the brush compartment and pull down to reveal two screws on a red fastener.
    • Remove them with the screwdriver.
  4. bObi Pet Edge Sensors  Replacement, Remove the Main Brush Attachment: 手順 4、 3の画像 1 bObi Pet Edge Sensors  Replacement, Remove the Main Brush Attachment: 手順 4、 3の画像 2 bObi Pet Edge Sensors  Replacement, Remove the Main Brush Attachment: 手順 4、 3の画像 3
    • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
    • Remove the 4 screws located beneath the brush compartment.
  5. bObi Pet Edge Sensors  Replacement, Remove the Cover Screws: 手順 5、 2の画像 1 bObi Pet Edge Sensors  Replacement, Remove the Cover Screws: 手順 5、 2の画像 2
    • Remove the 2 screws on the dustbin’s red fastener.
    • Remove the fastener and set it aside for reassembly.
    • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
  6. bObi Pet Edge Sensors  Replacement, Detach the Cover: 手順 6、 3の画像 1 bObi Pet Edge Sensors  Replacement, Detach the Cover: 手順 6、 3の画像 2 bObi Pet Edge Sensors  Replacement, Detach the Cover: 手順 6、 3の画像 3
    • Lift the cover to reveal the main board underneath.
    • Remove the two circuit plugs connecting the lid to the mainboard.
    • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
  7. bObi Pet Edge Sensors  Replacement, Unplug the Edge Sensors: 手順 7、 2の画像 1 bObi Pet Edge Sensors  Replacement, Unplug the Edge Sensors: 手順 7、 2の画像 2
    • bObi Pet has 4 edge sensors along her front edge.
    • They attach to the left side of her mainboard. Pull to remove the circuit plug.
    • If there is glue holding down the wires, you may scrape it off using your screwdriver.
  8. bObi Pet Edge Sensors  Replacement, Remove the Sensor Screws: 手順 8、 3の画像 1 bObi Pet Edge Sensors  Replacement, Remove the Sensor Screws: 手順 8、 3の画像 2 bObi Pet Edge Sensors  Replacement, Remove the Sensor Screws: 手順 8、 3の画像 3
    • There is one screw holding each edge sensor in place. Remove all four screws and keep them aside for reassembly.
  9. bObi Pet Edge Sensors  Replacement, Remove the Sensors: 手順 9、 3の画像 1 bObi Pet Edge Sensors  Replacement, Remove the Sensors: 手順 9、 3の画像 2 bObi Pet Edge Sensors  Replacement, Remove the Sensors: 手順 9、 3の画像 3
    • Do not remove the clear covers from the two sensors closest to bObi Pet's front wheel. If they get stuck to the sensors, simply replace them on bObi Pet.
    • Lift each of the sensor pieces out, and you'll be ready to install your new ones.
  10. bObi Pet Edge Sensors  Replacement, Attach the Covers: 手順 10、 3の画像 1 bObi Pet Edge Sensors  Replacement, Attach the Covers: 手順 10、 3の画像 2 bObi Pet Edge Sensors  Replacement, Attach the Covers: 手順 10、 3の画像 3
    • The outer two sensors will have smaller clear covers attached. Make sure to remove these two covers and attach them to the outer sensors on your replacement part.
    • One cover will fit on the sensor with red and white wires.
    • The other should be placed on the sensor with red and brown wires.
  11. bObi Pet Edge Sensors  Replacement, Connect the New Sensors: 手順 11、 3の画像 1 bObi Pet Edge Sensors  Replacement, Connect the New Sensors: 手順 11、 3の画像 2 bObi Pet Edge Sensors  Replacement, Connect the New Sensors: 手順 11、 3の画像 3
    • Attach the sensors’ circuit plug to the mainboard. You should be able to tell where each sensor sits on bObi Pet by the length of its wires.
    • The sensor with the shortest wire goes in front of bObi Pet's left wheel.
  12. bObi Pet Edge Sensors  Replacement, Place the New Sensors: 手順 12、 3の画像 1 bObi Pet Edge Sensors  Replacement, Place the New Sensors: 手順 12、 3の画像 2 bObi Pet Edge Sensors  Replacement, Place the New Sensors: 手順 12、 3の画像 3
    • The sensor with a green wire goes beside it. Then the yellow-wired sensor is next.
    • Then the final sensor and its cover will fit in front of bObi Pet's right wheel.
  13. bObi Pet Edge Sensors  Replacement, Secure the Sensors: 手順 13、 3の画像 1 bObi Pet Edge Sensors  Replacement, Secure the Sensors: 手順 13、 3の画像 2 bObi Pet Edge Sensors  Replacement, Secure the Sensors: 手順 13、 3の画像 3
    • Re-install one screw onto each sensor.
    • You may add glue or electrical tape to the new circuit plug for a more secure hold.
    • Be sure to tuck any protruding wires into the crevices around the mainboard and you’re ready to close the cover.
    • For help closing the cover, refer to the re-assembly guide: Assemble bObi Pet Post-Repair
終わりに
Congratulations on replacing bObi Pet's edge sensors! To finish off this repair, you'll want to close bObi Pet's cover. Find the guide here: Assemble bObi Pet Post-Repair
作成者
1人の作成者と共同作成されました。
Chelsea
メンバー登録日: 09/24/14
2,278 ポイント
31のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 227
