はじめに
in this guide we will replace a broken lcd cable.
we will also see how to open the laptop , so you can replace other parts..
if you want to replace a broken screen , start at step 17 -18
必要な工具と部品
now we will loosen the cable's from the main board.
remove the DC jack cable connected to the connector on the main board.
in the picture you see me using a IC axtractor, but i don't recommend it when you are not used to repair laptops...
when you are dealing with an broken DC jack , remove the whole cable ( black and red) running trough the plastic frame of the laptop...
remove the white big flat ribbon cable attached to the USB ( on the right) PCB.
again be careful and use a flat head screwdriver or a spudger to lift up the lever..
remove the audio cable from the connector , be careful if you tear the cables , you will have audio problems and there is a possibility that you will have BSOD ( blue screen of death) ...
remove the FAN cable from the connector , be very carefull because it are very tiny and breakeble cables...
remove the 3 screws seen in picture 1
remove 1 screw on the left side from the LCD connector.
after that, you can slide the main board out. ( lift it up on the right side, then slide to the right and take it out. )
when you want to remove the fan as well ( or replace it) you have to remove 3 screws, see picture 3
after removing the main board you have a view of the henges from the screen.
in picture 2 you will see the main board. , you can clean and or replace the CPU now.
to replace a cpu or clean the pads you will have to remove the screws seen in picture 3 .
clean the pads with isopropyl alcohol and always renew the CPU thermal paste . ( one drop on each spot is enough)
ある他の人がこのガイドを完成しました。
