メインコンテンツにスキップ
はじめに
Are you going to throw away your expensive massage pillow just because the heater is broken? Here is a simple guide to replace your broken heater so that your massage pillow can work again.
  1. Disconnect the power plug located on the back of the massage pillow. Please do this step carefully in order to avoid electric shock.
    • Disconnect the power plug located on the back of the massage pillow.
    • Please do this step carefully in order to avoid electric shock.
  2. Unzip the cover. You can locate the zipper at the back of the massage pillow. Take out the pillow so that you can manage the heater completely.
    • Unzip the cover. You can locate the zipper at the back of the massage pillow.
    • Take out the pillow so that you can manage the heater completely.
  3. Use a Phillips JIS #1 screwdriver to remove the screw at the center of the heater.
    • Use a Phillips JIS #1 screwdriver to remove the screw at the center of the heater.
    • The screw is 8.0mm.
  4. Remove the entire heater from the pillow. You can see a green circuit board after removing the heater.
    • Remove the entire heater from the pillow.
    • You can see a green circuit board after removing the heater.
  5. Using the Phillips JIS #1 screwdriver, remove the three screws circled in the picture.
    • Using the Phillips JIS #1 screwdriver, remove the three screws circled in the picture.
    • All three screws are 8.0mm, which are the same size as the previous one. They are interchangeable.
  6. Now you can take out the circuit board. There will be two wires attached to the circuit board.
    • Now you can take out the circuit board. There will be two wires attached to the circuit board.
    • If you prefer, you can clean the circuit board gently with dry tissues to remove the sticky lubricant.
  7. Use the pry bar to separate the wire from the white main board.
    • Use the pry bar to separate the wire from the white main board.
    • Before prying, check if you removed the power plug from the outlet and the massage pillow.
  8. Using your soldering station, remove the wires from the circuit board.
    • Using your soldering station, remove the wires from the circuit board.
    • If you don't know how to solder, you can check out this guide: How To Solder and Desolder Connections
    • Soldering can be dangerous. Be cautious of high heat soldering tools.
    • Now, you can separate the circuit board completely to replace with a new heater.
まとめ
ある他の人がこのガイドを完成しました。
Yuchen Li
メンバー登録日: 2015年09月28日
125 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-2, Green Fall 2015 Cal Poly, Team 14-2, Green Fall 2015人のメンバー
CPSU-GREEN-F15S14G2
4 メンバー
5のガイドは作成済み
Hi YuChen, nice work! Do you know from where I can find the switch for this heater? If you can tell me the part number, I can try looking it up on eBay. Thanks!
Abhishek Srivastava - 返信
YuChen, by any chance do you know where I can get the whole covering of this Shiatsu Massage Pillow. The fabric of mine has deteriorated and torn off. I have been trying to find one using Google search but was unable to find. Can you help, Thank you
gamesake2 - 返信
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 46
今までの合計 1,304
