この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide shows you how to replace the Zune Flash 2nd Generation face plate.
必要な工具と部品
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
Be sure to put this set of screws aside since they are a different size than any other screws in the device.
2 の人々がこのガイドを完成させました。
