メインコンテンツにスキップ
Zte Avail 2 Display Replacement
必要な工具と部品
  1. Zte Avail 2 Display Replacement, Battery: 手順 1、 3の画像 1 Zte Avail 2 Display Replacement, Battery: 手順 1、 3の画像 2 Zte Avail 2 Display Replacement, Battery: 手順 1、 3の画像 3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. Zte Avail 2 Display Replacement: 手順 2、 2の画像 1 Zte Avail 2 Display Replacement: 手順 2、 2の画像 2
    • Remove the battery by the notch in the back plate.
  3. Zte Avail 2 Display Replacement, Display: 手順 3、 1の画像 1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
  4. Zte Avail 2 Display Replacement: 手順 4、 2の画像 1 Zte Avail 2 Display Replacement: 手順 4、 2の画像 2
    • Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
  5. Zte Avail 2 Display Replacement: 手順 5、 2の画像 1 Zte Avail 2 Display Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. Zte Avail 2 Display Replacement: 手順 6、 1の画像 1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. Zte Avail 2 Display Replacement: 手順 7、 1の画像 1
    • Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
  8. Zte Avail 2 Display Replacement: 手順 8、 1の画像 1
    • Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
  9. Zte Avail 2 Display Replacement: 手順 9、 1の画像 1
    • Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
終わりに
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
dunnluke
メンバー登録日: 09/22/15
237 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 1-6, Sydow campbell Fall 2015 University of Alabama, Team 1-6, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G6
5 メンバー
8のガイドは作成済み
コメント 1 件
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
Joyce - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 986
