メインコンテンツにスキップ
Zoomer Dino Boomer Main Circuit Board Replacement
必要な工具と部品
  1. Zoomer Dino Boomer Main Circuit Board Replacement, Back Cover: 手順 1、 1の画像 1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Main Circuit Board Replacement: 手順 2、 2の画像 1 Zoomer Dino Boomer Main Circuit Board Replacement: 手順 2、 2の画像 2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Main Circuit Board Replacement: 手順 3、 3の画像 1 Zoomer Dino Boomer Main Circuit Board Replacement: 手順 3、 3の画像 2 Zoomer Dino Boomer Main Circuit Board Replacement: 手順 3、 3の画像 3
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 手順 4、 3の画像 1 Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 手順 4、 3の画像 2 Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 手順 4、 3の画像 3
    • Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board.
  5. Zoomer Dino Boomer Main Circuit Board Replacement: 手順 5、 2の画像 1 Zoomer Dino Boomer Main Circuit Board Replacement: 手順 5、 2の画像 2
    • Remove legs.
  6. Zoomer Dino Boomer Main Circuit Board Replacement: 手順 6、 1の画像 1
    • Remove the three 7.2 mm Phillips #0 screws connecting the main circuit board to the body of Zoomer Dino Boomer.
  7. Zoomer Dino Boomer Main Circuit Board Replacement: 手順 7、 3の画像 1 Zoomer Dino Boomer Main Circuit Board Replacement: 手順 7、 3の画像 2 Zoomer Dino Boomer Main Circuit Board Replacement: 手順 7、 3の画像 3
    • Use soldering iron and tweezers to disconnect main circuit board from the black and red wires.
    • Check out iFixit's soldering techniques guide to learn more about soldering and desoldering connections.
    • Remove main circuit board from Zoomer Dino Boomer
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Desiree DesJardins
メンバー登録日: 09/02/15
452 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015人のメンバー
USFT-WOLLERT-F15S16G1
3 メンバー
10のガイドは作成済み
3 件のコメント
can anyone tell me where to get a replacement motherboard?
alan.scott - 返信
Nah cuz my dino doesn't show any life support at all just the controller and Idek what's the issue. If this is the way to solve it be so for real tell me where to get that new circuit.
Nightmare_Requiem - 返信
The batteries location?
Tony Beatenbo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 4,425
