メインコンテンツにスキップ
Zoombak Personal GPS Locator Battery Replacement
必要な工具と部品
  1. Zoombak Personal GPS Locator Battery Replacement, Battery: 手順 1、 1の画像 1
    • Zoombak Personal GPS device
  2. Zoombak Personal GPS Locator Battery Replacement: 手順 2、 1の画像 1
    • Backside has four rubber plugs. Remove them and find the Phillips head screws.
  3. Zoombak Personal GPS Locator Battery Replacement: 手順 3、 1の画像 1
    • Use a small tip flat blade screw driver to remove the rubber plugs.
  4. Zoombak Personal GPS Locator Battery Replacement: 手順 4、 1の画像 1
    • Plugs removed
  5. Zoombak Personal GPS Locator Battery Replacement: 手順 5、 1の画像 1
    • Rubber plugs
  6. Zoombak Personal GPS Locator Battery Replacement: 手順 6、 1の画像 1
    • Remove the bottom cover.
  7. Zoombak Personal GPS Locator Battery Replacement: 手順 7、 1の画像 1
    • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  8. Zoombak Personal GPS Locator Battery Replacement: 手順 8、 1の画像 1
    • The old one was swollen from being on the charger for so long.
  9. Zoombak Personal GPS Locator Battery Replacement: 手順 9、 1の画像 1
    • The case without the battery.
  10. Zoombak Personal GPS Locator Battery Replacement: 手順 10、 1の画像 1
    • New battery installed.
  11. Zoombak Personal GPS Locator Battery Replacement: 手順 11、 1の画像 1
    • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
James
メンバー登録日: 10/04/10
113 ポイント
1ガイドが承認済み
2 件のコメント
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - 返信
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 4,247
