メインコンテンツにスキップ
Zoom Q3HD Handy Video Recorder Lens Cleaning
必要な工具と部品
  1. Zoom Q3HD Handy Video Recorder Lens Cleaning, Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 1、 1の画像 1
    • Remove the two screws from the bottom of the device.
    • Make sure to put your screws in a safe place.
  2. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 2、 1の画像 1
    • Flip the device over and remove the four screws bordering the grate of the device.
  3. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 3、 1の画像 1
    • On the front of the device, slide the battery compartment cover off by pushing inward and sliding downward.
  4. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 4、 1の画像 1
    • Remove the two screws from the lip of the battery compartment.
  5. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 5、 1の画像 1
    • Remove the final screw from the bed of the battery compartment.
  6. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 6、 1の画像 1
    • WARNING: Pieces may become loose when you separate the device in half!
    • Run the pry tool along the edges of the device to begin separating the device in two halves.
  7. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 7、 2の画像 1 Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 7、 2の画像 2
    • REMINDER: Pieces may become loose when you separate the device in half!
    • Apply upward pressure to fully separate the device into two halves.
  8. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 8、 1の画像 1
    • WARNING: If you’re not careful with keeping the screen close to the board, you will rip off the ribbon attaching the screen to the circuit board.
    • Lift display screen keeping the top half close to the board.
  9. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 9、 1の画像 1
    • Gently flip the black clip up attaching the ribbon of the screen to the circuit board.
  10. Zoom Q3HD Handy Video Recorder Lens Cleaning: 手順 10、 1の画像 1
    • Gently slide the ribbon from the circuit board, removing the screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Grace Bently
メンバー登録日: 10/13/14
4 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Mccook Fall 2014 Ohio State, Team 1-1, Mccook Fall 2014人のメンバー
OSU-MCCOOK-F14S1G1
4 メンバー
1のガイドは作成済み
3 件のコメント
My zoom q3HD only have the red light turned on when powering up. No display at all. What is happening? How can I claim warranty? I didn't use the device more than a year. Help me
stancalvin - 返信
This is not comlete, leaves you half way through, would be great if you could finish this, thank you.
smoldas.l - 返信
Yes it would be good to see it finished. I am half way through taking mine apart to clean the lens amd i don't know if i should proceed or not. Its the 2nd time the lens has fogged up. My 2nd q3hd.
steven kemsley - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 1,986
