メインコンテンツにスキップ
Zoom H1 Handy Recorder Speaker Replacement
必要な工具と部品
  1. Zoom H1 Handy Recorder Speaker Replacement, Speaker: 手順 1、 1の画像 1
    • Turn the device over with its display down.
  2. Zoom H1 Handy Recorder Speaker Replacement: 手順 2、 1の画像 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Speaker Replacement: 手順 3、 1の画像 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
  4. Zoom H1 Handy Recorder Speaker Replacement: 手順 4、 1の画像 1
    • Carefully pry up the top end of the back cover using one finger.
  5. Zoom H1 Handy Recorder Speaker Replacement: 手順 5、 1の画像 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Speaker Replacement: 手順 6、 1の画像 1
    • De-solder the white and black speaker wires from their soldering points.
    • Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
    • Keep in mind which color wire was connected at which terminal.
  7. Zoom H1 Handy Recorder Speaker Replacement: 手順 7、 1の画像 1
    • Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
    • You will have to break the glue holding the speaker in place before removing it.
  8. Zoom H1 Handy Recorder Speaker Replacement: 手順 8、 1の画像 1
    • Replace the damaged speaker and re-solder to the original solder points.
    • Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
終わりに
作成者
6人の作成者と共同で作成されました。
Alex
メンバー登録日: 10/28/13
809 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 16
今までの合計 1,712
