はじめに
Welcome to the Zoom H1 Handy Recorder guide to replace the microphone. It will happen at times that the microphone corrodes, suffers damage, or ages in quality, making the device not collect sound properly or any at all. This guide will provide step-by-step instructions to help you replace the microphone. Although this guide is easy to follow, there is a special skill necessary: soldering.
Caution! About soldering: there are some hazards to be aware of, necessary equipment, and the act of soldering itself. iFixit features a Wiki on soldering, and will teach you the necessary skills to help you make your Zoom H1 Handy Recorder work like new again!
必要な工具と部品
Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
There is a third screw under the warranty label with number next to the battery cover.
Unscrew the blue circuit board.
The board is held down by a single screw located at the bottom of the device, just to the left of the lowest battery terminal.
Insert the tip of the angled tweezers into the hole in the black plastic located within the microphone case. Use the tweezers to pull the microphone out of the casing.
5 の人々がこのガイドを完成させました。
5 件のコメント
Thanks for the procedure. but you did not say where to get the new microphones from. What kind of microphone should we buy and where can they be bought from.
What kind of microphone should we buy and where can they be bought from. I need information.
Radityo HR - 返信
Attention! There are differet versions of this Rocorder. My H1 had a 3rd screw under the SerialNo. lable, you have to remove first.
mine also has a third screw near the battery, under the serial number. where to buy a new microphone?
Please insert in the guide some link to buy the replacement mic
