メインコンテンツにスキップ
Zoom H1 Handy Recorder Battery Terminal Replacement
必要な工具と部品
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: 手順 1、 1の画像 1
    • Place the device so the display is down.
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 2、 1の画像 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 3、 1の画像 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 4、 1の画像 1
    • Carefully pry up the top end of the back cover using one finger
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 5、 1の画像 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 6、 1の画像 1
    • De-solder at terminal point one.
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 7、 1の画像 1
    • De-solder at the second terminal point.
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 8、 2の画像 1 Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 8、 2の画像 2
    • Remove the faulty terminals
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 9、 1の画像 1
    • Place new lead in at point one and re-solder at the point.
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: 手順 10、 1の画像 1
    • Place second lead at point 2 and re-solder.
終わりに
To Re-construct device, perform these steps in reverse order.
作成者
7人の作成者と共同で作成されました。
Alex
メンバー登録日: 10/28/13
809 ポイント
5のガイドは作成済み
7 件のコメント
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - 返信
Mine has third screw under the serial-number sticker.
halluciana - 返信
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - 返信
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - 返信
Same problem, without any reason it is dead
eevilcute -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 29
今までの合計 6,379
