メインコンテンツにスキップ
Zippo Lighter Felt Pad and Cotton Replacement
必要な工具と部品
  1. Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 手順 1、 3の画像 1 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 手順 1、 3の画像 2 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 手順 1、 3の画像 3
    • Open the lid of the lighter.
    • Hold the bottom of the lighter’s case and pull out the metal container.
    • Set the case aside for now.
  2. Zippo Lighter Felt Pad and Cotton Replacement: 手順 2、 2の画像 1 Zippo Lighter Felt Pad and Cotton Replacement: 手順 2、 2の画像 2
    • Turn the metal container upside down with the bottom facing you.
    • You should see a piece of white felt with the words “Lift to fill.”
  3. Zippo Lighter Felt Pad and Cotton Replacement: 手順 3、 2の画像 1 Zippo Lighter Felt Pad and Cotton Replacement: 手順 3、 2の画像 2
    • Loosen the screw with a flathead screwdriver.
    • There is a spring behind the screw, so make sure you are unscrewing slowly and gently.
    • Remove the screw with the spring and the flint attached to it.
  4. Zippo Lighter Felt Pad and Cotton Replacement: 手順 4、 2の画像 1 Zippo Lighter Felt Pad and Cotton Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Lift the felt pad up and out of the metal container using a pair of tweezers.
  5. Zippo Lighter Felt Pad and Cotton Replacement: 手順 5、 2の画像 1 Zippo Lighter Felt Pad and Cotton Replacement: 手順 5、 2の画像 2
    • Use a pair of tweezers to remove the old cotton from the inside.
    • When adding new cotton, it should fully cover the inside of the metal canister.
    • Throw the old felt and cotton in the garbage.
  6. Zippo Lighter Felt Pad and Cotton Replacement: 手順 6、 3の画像 1 Zippo Lighter Felt Pad and Cotton Replacement: 手順 6、 3の画像 2 Zippo Lighter Felt Pad and Cotton Replacement: 手順 6、 3の画像 3
    • Use a pair of tweezers to push each cotton piece on top of the wick inside the metal container. Make sure the cotton pieces cover all the sides.
  7. Zippo Lighter Felt Pad and Cotton Replacement: 手順 7、 1の画像 1
    • Use a pair of tweezers to place the new felt pad on top of the cotton pieces.
  8. Zippo Lighter Felt Pad and Cotton Replacement: 手順 8、 2の画像 1 Zippo Lighter Felt Pad and Cotton Replacement: 手順 8、 2の画像 2
    • Replace the flint and screw it back into place using a flathead screwdriver.
  9. Zippo Lighter Felt Pad and Cotton Replacement: 手順 9、 2の画像 1 Zippo Lighter Felt Pad and Cotton Replacement: 手順 9、 2の画像 2
    • Refuel your lighter, put the metal container back inside the case, and test out the lighter.
    • Only use the lighter when it is secured inside the case.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Dara
メンバー登録日: 10/01/21
193 ポイント
1ガイドが承認済み
チーム
York University, Team G-35, O'Regan Fall 2021 York University, Team G-35, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21SGG35
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 36
過去 30 日: 162
今までの合計 8,872
