メインコンテンツにスキップ
Zenithink ZTPAD ZT280 C91 Screen Replacement
必要な工具と部品
  1. Zenithink ZTPAD ZT280 C91 Screen Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 2、 3の画像 1 Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 2、 3の画像 2 Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 2、 3の画像 3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Zenithink ZTPAD ZT280 C91 Screen Replacement, Motherboard: 手順 3、 1の画像 1
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 4、 1の画像 1
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 5、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  6. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 6、 1の画像 1
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  7. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 7、 2の画像 1 Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 7、 2の画像 2
    • Slide back the plastic latch for the camera cable.
  8. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 8、 1の画像 1
    • Peel back the reflective tape.
  9. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 9、 2の画像 1 Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 9、 2の画像 2
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  10. Zenithink ZTPAD ZT280 C91 Screen Replacement, Front Panel: 手順 10、 1の画像 1
    • Remove the four highlighted screws using a Phillips #1 screwdriver.
    • For differentiation purposes, these screws are 4mm long and have a larger head than the rest of the screws.
  11. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 11、 1の画像 1
    • Starting from the top, slowly lift everything up out of the front panel.
    • Remove the front panel off of the device.
    • Be careful not to damage the ports along the bottom.
  12. Zenithink ZTPAD ZT280 C91 Screen Replacement, Screen: 手順 12、 1の画像 1
    • Peel back the adhesive from one of the top corners.
    • We recommend to use only your hands to avoid damage to the battery.
  13. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 13、 1の画像 1
    • While you're peeling the adhesive back, be careful because the display is connected by a cable on the right.
  14. Zenithink ZTPAD ZT280 C91 Screen Replacement: 手順 14、 1の画像 1
    • Using tweezers, slide back the latch and unplug the ribbon cable.
    • Remove the display from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Nicholas Davis
メンバー登録日: 09/21/18
345 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S6-G1, Thompson Fall 2018 University of North Texas, Team S6-G1, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S6G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 182
