この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In the process of disconnecting the motherboard you will begin with taking off 4 screws with a phillips screwdriver. Once that is done you should be careful with disconnecting all the cables connected to the board, making sure you don't tear any of the wires.
必要な工具と部品
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
2 の人々がこのガイドを完成させました。
