メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This camera replacement guide should only be done once the prerequisite steps have been fully completed. Skipping any steps can lead to damage to your device.
パーツ
パーツは指定されていません。
  1. Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Using a spudger, start prying the case apart by working around the edge slowly. Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger. While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Flip up the small gate and unplug the ribbon cable shown.
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  6. Slide back the plastic latch for the main display cable.
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  7. Slide back the plastic latch for the camera cable. Carefully unplug the cable with tweezers.
    • Slide back the plastic latch for the camera cable.
  8. Peel back the reflective tape.
    • Peel back the reflective tape.
  9. Lift up the motherboard assembly, starting by lifting up the top. Be careful not to damage any of the ports on the underside of the tablet.
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  10. Peel back the adhesive tape holding the camera in place.
    • Peel back the adhesive tape holding the camera in place.
    • Remove the camera from the device.
終わりに
ある他の人がこのガイドを完成しました。
Keelie Beach
メンバー登録日: 2018年09月21日
414 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S6-G1, Thompson Fall 2018 University of North Texas, Team S6-G1, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S6G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 62
