メインコンテンツにスキップ
Zenbre SoundBank Z3 Battery Replacement
必要な工具と部品
  1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: 手順 1、 2の画像 1 Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: 手順 1、 2の画像 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Battery Replacement: 手順 2、 1の画像 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Battery Replacement: 手順 3、 2の画像 1 Zenbre SoundBank Z3 Battery Replacement: 手順 3、 2の画像 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 手順 4、 3の画像 1 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 手順 4、 3の画像 2 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 手順 4、 3の画像 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Battery Replacement, Battery: 手順 5、 2の画像 1 Zenbre SoundBank Z3 Battery Replacement, Battery: 手順 5、 2の画像 2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Zenbre SoundBank Z3 Battery Replacement: 手順 6、 2の画像 1 Zenbre SoundBank Z3 Battery Replacement: 手順 6、 2の画像 2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Zenbre SoundBank Z3 Battery Replacement: 手順 7、 1の画像 1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
終わりに
3 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Cherian Thomas
メンバー登録日: 03/25/16
334 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S3G2
5 メンバー
8のガイドは作成済み
3 件のコメント
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - 返信
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas -
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Alier Obed Jaenz Rivas - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 4,565
