この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This is a guide for replacing the motherboard of your Zeki device. To reach the motherboard, first remove the plastic backing. Then, the battery, and camera. After replacing the motherboard, the device will need to be reassembled in the opposite order.
必要な工具と部品
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Remove the Wi-Fi antenna element, which is highlighted by red in the picture, from the front plate.
2 の人々がこのガイドを完成させました。
