メインコンテンツにスキップ
Zebco 33 The Spool and the Line Replacement
必要な工具と部品
  1. Zebco 33 The Spool and the Line Replacement, The Spool and the Line: 手順 1、 1の画像 1
    • Remove the old line remaining on the Zebco 33 by pressing down on the large spool release button on the back of the reel. Pull the old line off the reel.
  2. Zebco 33 The Spool and the Line Replacement: 手順 2、 1の画像 1
    • Open the front spool cover of the Zebco 33 reel by turning it to the left and pulling it straight off.
  3. Zebco 33 The Spool and the Line Replacement: 手順 3、 1の画像 1
    • Cut the line free from the Zebco 33 spool. Pull the line through the front spool cover and then through the line.
  4. Zebco 33 The Spool and the Line Replacement: 手順 4、 1の画像 1
    • Thread the line through the hole in the center of the front spool cover and then around the spool of the reel.
  5. Zebco 33 The Spool and the Line Replacement: 手順 5、 1の画像 1
    • Attach the line to the spool of the Zebco 33 with a knot. Double the knot and then pull the knot down tightly against the spool of the reel. Clip the extra line from the knot.
  6. Zebco 33 The Spool and the Line Replacement: 手順 6、 1の画像 1
    • Put the front spool cover back on the reel. Hold the line a few inches in front of the spool and apply slight tension to the line. Wind the line onto the reel by turning the handle of the reel.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Renecee
メンバー登録日: 02/02/16
131 ポイント
1ガイドが承認済み
チーム
2 件のコメント
I have a 33K that I cant get the front cover off. I need advice please jamkauf48@gmail.com
James Kaufman - 返信
Instructions need to be much clearer and pictures must be clear.
Functions are difficult to understand……..
Wayne Yeager - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 128
過去 30 日: 629
今までの合計 55,977
