メインコンテンツにスキップ
はじめに
When your memory card is full, you can follow these steps to install another microSD card in your iON.
  1. Peel the rubber cover for the memory card and USB port away from the goggles. Be careful not to completely remove the cover!
    • Peel the rubber cover for the memory card and USB port away from the goggles.
    • Be careful not to completely remove the cover!
  2. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  3. Push the memory card in until you hear it click. Pull your finger away.
    • Push the memory card in until you hear it click.
    • Pull your finger away.
    • If you pull your finger away too quickly, the card can completely pop out of the slot and could get lost!
    • The memory card will pop out about half way out of its slot.
  4. Pull the memory card straight out of its slot. Pull the memory card straight out of its slot.
    • Pull the memory card straight out of its slot.
まとめ
Eric Flores
メンバー登録日: 2012年07月31日
128 ポイント
9のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,199
