メインコンテンツにスキップ
Zeal Optics iON LCD Replacement
必要な工具と部品
  1. Zeal Optics iON LCD Replacement, Lens: 手順 1、 2の画像 1 Zeal Optics iON LCD Replacement, Lens: 手順 1、 2の画像 2
    • In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
    • Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
    • Pull the rubber housing apart to release the first two clips.
  2. Zeal Optics iON LCD Replacement: 手順 2、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 2、 2の画像 2
    • Grab the inside of the plastic nose rest with your thumb and index finger.
    • Rotate the nose rest upwards until you feel that it is free from the lens.
  3. Zeal Optics iON LCD Replacement: 手順 3、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 3、 2の画像 2
    • Rotate the device 180 degrees.
    • Grab the top of the goggle frame that holds the camera assembly.
    • Rotate the frame outwards until you feel that the clips inside it are free.
  4. Zeal Optics iON LCD Replacement: 手順 4、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 4、 2の画像 2
    • While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
  5. Zeal Optics iON LCD Replacement: 手順 5、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 5、 2の画像 2
    • The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips.
    • While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
  6. Zeal Optics iON LCD Replacement, Camera Assembly: 手順 6、 1の画像 1
    • Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
  7. Zeal Optics iON LCD Replacement: 手順 7、 3の画像 1 Zeal Optics iON LCD Replacement: 手順 7、 3の画像 2 Zeal Optics iON LCD Replacement: 手順 7、 3の画像 3
    • Peel back the rubber battery cover from the inner left side of the frame.
    • While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
  8. Zeal Optics iON LCD Replacement: 手順 8、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 8、 2の画像 2
    • Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
  9. Zeal Optics iON LCD Replacement: 手順 9、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 9、 2の画像 2
    • Pull the battery out of its recess in the frame.
    • The battery is connected to the entire camera assembly and cannot be completely removed by itself.
  10. Zeal Optics iON LCD Replacement: 手順 10、 3の画像 1 Zeal Optics iON LCD Replacement: 手順 10、 3の画像 2 Zeal Optics iON LCD Replacement: 手順 10、 3の画像 3
    • Peel the rubber keypad cover up from the inner right side of the frame.
    • While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
  11. Zeal Optics iON LCD Replacement: 手順 11、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 11、 2の画像 2
    • Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
  12. Zeal Optics iON LCD Replacement: 手順 12、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 12、 2の画像 2
    • Hold the strap mount cover away from the frame and remove the keypad.
  13. Zeal Optics iON LCD Replacement: 手順 13、 3の画像 1 Zeal Optics iON LCD Replacement: 手順 13、 3の画像 2 Zeal Optics iON LCD Replacement: 手順 13、 3の画像 3
    • Grab the viewfinder housing and pull it out of its recess.
    • Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
  14. Zeal Optics iON LCD Replacement: 手順 14、 3の画像 1 Zeal Optics iON LCD Replacement: 手順 14、 3の画像 2 Zeal Optics iON LCD Replacement: 手順 14、 3の画像 3
    • Place one of your hands near the center of the frame with your thumb next to the camera housing.
    • With your other hand, grab the camera housing and pull it up and out of the frame.
  15. Zeal Optics iON LCD Replacement: 手順 15、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 15、 2の画像 2
    • Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
  16. Zeal Optics iON LCD Replacement: 手順 16、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 16、 2の画像 2
    • In the same manner described above, remove the battery from the frame.
  17. Zeal Optics iON LCD Replacement, Viewfinder Lens Assembly: 手順 17、 2の画像 1 Zeal Optics iON LCD Replacement, Viewfinder Lens Assembly: 手順 17、 2の画像 2
    • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
    • Flip the viewfinder housing over 180 degrees.
    • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
  18. Zeal Optics iON LCD Replacement: 手順 18、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 18、 2の画像 2
    • Pull the two halves of the viewfinder housing apart.
  19. Zeal Optics iON LCD Replacement: 手順 19、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 19、 2の画像 2
    • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Be sure to pry up on the hinged flap, not the connector itself.
  20. Zeal Optics iON LCD Replacement: 手順 20、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 20、 2の画像 2
    • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
  21. Zeal Optics iON LCD Replacement: 手順 21、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 21、 2の画像 2
    • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
  22. Zeal Optics iON LCD Replacement: 手順 22、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 22、 2の画像 2
    • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
  23. Zeal Optics iON LCD Replacement: 手順 23、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 23、 2の画像 2
    • Remove the viewfinder lens assembly from the viewfinder housing.
  24. Zeal Optics iON LCD Replacement, LCD Assembly: 手順 24、 2の画像 1 Zeal Optics iON LCD Replacement, LCD Assembly: 手順 24、 2の画像 2
    • Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly.
    • Pull the viewfinder lens off of the viewfinder LCD.
  25. Zeal Optics iON LCD Replacement, LCD: 手順 25、 3の画像 1 Zeal Optics iON LCD Replacement, LCD: 手順 25、 3の画像 2 Zeal Optics iON LCD Replacement, LCD: 手順 25、 3の画像 3
    • Use your thumb to push the LCD bracket tab away from the LCD.
    • Remove the LCD bracket from the LCD and backlight.
  26. Zeal Optics iON LCD Replacement: 手順 26、 2の画像 1 Zeal Optics iON LCD Replacement: 手順 26、 2の画像 2
    • Using your thumbs, pull the four white tabs on the backlight away from the LCD panel.
    • Remove the LCD from the backlight.
終わりに
作成者
3人の作成者と共同で作成されました。
Eric Flores
メンバー登録日: 07/31/12
128 ポイント
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,283
