はじめに
No button response or viewfinder image in your Zeal Optics iON goggles? Use this guide to replace a faulty button board, which also connects to the viewfinder lens assembly.
必要な工具と部品
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Use the tip of a spudger to flip up the retaining flap on the button board data cable ZIF connector.
ある他の人がこのガイドを完成しました。
