はじめに
Over time, the battery life can run low and stop recharging. This guide will show you how to replace the battery. You will need a plastic opening tool, tweezers, a Phillips #00 screwdriver, a heat gun, and a plastic spudger to complete this guide.
必要な工具と部品
Flip the phone over so that the back panel of the phone is facing up.
Wedge the plastic opening tool between the black outer panel and the silver side panel.
Push down on the plastic opening tool to separate the back panel from the rest of the phone.
Continue to do this around all sides of the phone until the back panel has popped all the way off.
18 の人々がこのガイドを完成させました。
14 件のコメント
This is much more difficult than it is depicted; while I’m not an electrician, I’ve acquired skills as a sailor over the past 8 years. Damage to the device is nearly guaranteed. I would NOT recommend trying this operation.
Have you actually tried? With the proper tools and care it doesn’t seem that difficult. But then I was a computer tech and repaired laptops. For anyone inexperienced or lacking patience, you’re probably right.
It’s actually pretty easy. I’m guessing your main concern is ESD… You can avoid electrostatic discharge by using the proper tooling and ESD mats.
The instructions were good. Please note the cable under the yellow tape is very thin and not really visible against the backdrop. Mine tore and made camera not function correctly.
Also note, I couldn't remove the last screw off the motherboard. It was too tightly inserted and was stripping by attempts. I turned my phone face down with gorilla glass against a heating pad on a low setting for just a few minutes to warm the adhesive on the battery. Keep the top section with the motherboard off the heating pad. This was the easiest thing to remove. Use a plastic spatula not a metallic one.
