メインコンテンツにスキップ
ZTE ZMax Pro Back Panel Assembly Replacement
必要な工具と部品
  1. ZTE ZMax Pro Back Panel Assembly Replacement, Back Panel Assembly: 手順 1、 1の画像 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Back Panel Assembly Replacement: 手順 2、 1の画像 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Back Panel Assembly Replacement: 手順 3、 2の画像 1 ZTE ZMax Pro Back Panel Assembly Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Back Panel Assembly Replacement: 手順 4、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Back Panel Assembly Replacement: 手順 5、 1の画像 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Back Panel Assembly Replacement: 手順 6、 2の画像 1 ZTE ZMax Pro Back Panel Assembly Replacement: 手順 6、 2の画像 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Back Panel Assembly Replacement: 手順 7、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Back Panel Assembly Replacement: 手順 8、 1の画像 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
終わりに
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Mihir Deshmukh
メンバー登録日: 04/18/18
405 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S17-G3, Livingston Spring 2018 Cal Poly, Team S17-G3, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S17G3
4 メンバー
16のガイドは作成済み
1件のガイドコメント
When I tried this at step 8 the screen peeled off instead of the top cover. Ruined my phone.
Solomon Martinez - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 18
今までの合計 1,043
