はじめに
This guide provides the steps necessary to replace the front-facing camera on the ZTE ZFive G LTE.
  1. Using the opening tool, pry open the rear cover from the crease at the bottom left corner. Using the opening tool, pry open the rear cover from the crease at the bottom left corner. Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
    • Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
  2. Remove the battery with an opening tool or fingernail. Remove the battery with an opening tool or fingernail. Remove the battery with an opening tool or fingernail.
    • Remove the battery with an opening tool or fingernail.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Unscrew all 16 screws from the mid-frame J000 screwdriver.
    • Unscrew all 16 screws from the mid-frame J000 screwdriver.
    • Set the screws aside.
  5. Gently pull up the device body from the inside. Make sure to pull on all four sides as shown here.
    • Gently pull up the device body from the inside.
    • Make sure to pull on all four sides as shown here.
  6. Once the body is removed, you will see the front facing camera at the top right corner of the device. Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
    • Once the body is removed, you will see the front facing camera at the top right corner of the device.
    • Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
  7. Using angled tweezers, gently pull the ribbon wire up from the body. With the ribbon wire out, you should be able to remove the camera.
    • Using angled tweezers, gently pull the ribbon wire up from the body.
    • With the ribbon wire out, you should be able to remove the camera.
    • If there is adhesive on the camera backing, it may require more force to pull the camera out.
まとめ
Julian Mendoza
メンバー登録日: 2018年09月21日
698 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S1-G1, Riccardelli Fall 2018 University of North Texas, Team S1-G1, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G1
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 169
