メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ZTE Telstra T95 Keypad Replacement
必要な工具と部品
  1. ZTE Telstra T95 Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Keypad Replacement: 手順 2、 1の画像 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
  3. ZTE Telstra T95 Keypad Replacement, SIM Card: 手順 3、 1の画像 1
  4. ZTE Telstra T95 Keypad Replacement: 手順 4、 1の画像 1
    • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
  5. ZTE Telstra T95 Keypad Replacement: 手順 5、 2の画像 1 ZTE Telstra T95 Keypad Replacement: 手順 5、 2の画像 2
    • Remove the SIM card by placing your index finger over it and sliding it out.
    • When you are ready to re-insert the SIM card make sure the pink side facing up.
  6. ZTE Telstra T95 Keypad Replacement, Keypad: 手順 6、 1の画像 1
    • Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
    • Screw sizes are 1.42mm in width and 3.37mm in length.
  7. ZTE Telstra T95 Keypad Replacement: 手順 7、 1の画像 1
    • Remove front casing by sliding a plastic opening tool between the chrome layer and the top cover.
  8. ZTE Telstra T95 Keypad Replacement: 手順 8、 1の画像 1
    • The buttons should come off with the front casing but sometimes they don't. If that is the case simply remove them using your fingers and place them with the front cover.
    • If your keypad buttons are sticky you can clean them in this step.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Dioselina M Varela
メンバー登録日: 10/25/14
261 ポイント
2のガイドは作成済み
チーム
Gateway, Team 1-1, Johnson Fall 2014 Gateway, Team 1-1, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G1
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 47
今までの合計 417
