メインコンテンツにスキップ
はじめに
Has your ZTE Quest’s rear-facing camera been badly scratched or damaged? This guide will provide instructions on how to replace your camera. All you need is a plastic opening tool, some tweezers, and a JIS #000 screwdriver.
  1. Ensure that the phone is turned off before starting. Orient the device so that the inset on the right side of the device is facing you. Insert the spudger into the inset and carefully remove the back panel.
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. Use the ribbon to remove the exposed battery. Use the ribbon to remove the exposed battery.
    • Use the ribbon to remove the exposed battery.
  3. Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  5. Carefully pry open the back panel with the plastic opening tool.
    • Carefully pry open the back panel with the plastic opening tool.
  6. Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  7. Pull back the tape encasing the brown ribbon cable connector.
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  8. Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  9. Disconnect the coaxial connector in the bottom right corner of the motherboard. Disconnect the coaxial connector in the bottom right corner of the motherboard.
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
  10. Flip the motherboard over and find the camera’s flat-top connector.
    • Flip the motherboard over and find the camera’s flat-top connector.
    • Gently pry up each side of the connector with a pair of tweezers before fully removing it.
まとめ
Eric Loureiro
メンバー登録日: 2018年10月26日
469 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G6, Peak Fall 2018 UMass Dartmouth, Team S3-G6, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S3G6
3 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 68
